Discussion topic: Sky business not working
This message was authored by: RachelScott1
Our Sky TV is not working, we have a satellite dish, we require an engineer
Re: Sky business not working
@RachelScott1
Any error message on screen?
Avatar for RachelScott1
Level 0 icon
Says No satellite signal
@RachelScott1
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Title say 'Sky Business'?
If so, it's a different contact point: https://business.sky.com/
