2
This discussion topic has been answered Discussion topic: Sky box wont turn on have unplug repeatedly
This message was authored by: hughie31
Sky box has a red light a d a tallow one after unplugging and replacing it still won't turn on
Re: Sky box wont turn on have unplug repeatedly
Hi @hughie31
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Hi @hughie31
Avatar for hughie31
Thanks that worked
