Discussion topic: Sky box won't switch off or change channels
Message posted on 17 Nov 2024 10:24 PM
Sky Q box won't switch off or change channels
Message posted on 18 Nov 2024 09:37 AM
Re: Sky box won't switch off or change channels
Hi @Suzyb00
Have you tried rebooting your Q box?
If you had to press the Standby button on the front of the Q box (Amber led) to switch it on then
