Discussion topic: Sky box won’t connect to the network. I can watch live tv and recordings but no demand services
This message was authored by: suzanne7566
Sky is saying there is a problem with your network connection. To check settings select network set up. When I press that it asks me if to select  connect to ski broadband router if I have sky broadband which I do. It then asks me to hold down wps button but nothing happens , it just says searching and eventually it boots me out
This message was authored by: Tomasso
Re: Sky box won’t connect to the network. I can watch live tv and recordings but no demand services
I'm having the exact same problem. Everything is connecting the router as normal, but the sky q box will not. The WPS just times out. I've tried rebooting the box, but that hasn't helped. I've tried to manually enter the password but that doesn't work either
