Discussion topic: Sky box won't connect to the Internet
This message was authored by: Stuart2212
Re: Sky box won't connect to the Internet
Might be wise to provide a bit more information on what is happening or if you have made any recent changes to your setup, router or broadband provider..
But, follow this Sky Q help article to see if it can help fix your problem;
Sky Q connectivity problems | Sky Help | Sky.com
This message was authored by: Liam+Doyle
After i changed my sky package yesterday i went home from work and had no internet
Avatar for Stuart2212
We had a power cut 7 days ago and every since the the green circle on the middle. Of the sky box as been blue. Internet is working via are phones a d laptops, but sky want record anything and it just says not connected we have tried going via setting and startup buy nothing has rectified it
What was changed in your Sky package?
