Discussion topic: Sky box will not connect with router
Message posted on 15 Dec 2023 10:47 PM
Sky box connection with router seems to have dropped out. Been through reset process using wps button bu unsuccessful on several attempts
Message posted on 15 Dec 2023 11:06 PM
Re: Sky box will not connect with router
Hi @JBJB
Have you carried outa Network reset Exactly as follows?
Try a Network Reset found in Q box Home - Settings - Setup - Network.
