Discussion topic: Sky box showing amber light
Message posted on 30 May 2024 12:10 PM
Sky box is showing amber light and I've tried repairing the remote and it's not working
Message posted on 30 May 2024 12:17 PM
Re: Sky box showing amber light
Hi @Lilyll
The Q box needs to on to re pair the remote.
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on 30 May 2024 01:23 PM
My mam had the same. I cleared allot of her recordings which brought back the green light
