Discussion topic: Sky box office tnt recording won't play
Message posted on 17 Nov 2024 11:24 AM
I've ordered the UFC event last night and it's recorded. But now it won't play when I selected from recordings
Message posted on 17 Nov 2024 11:27 AM
Re: Sky box office tnt recording won't play
Hi @Gazowens
Have you tried rebooting your Q box?
Message posted on 17 Nov 2024 11:28 AM
Yeah mate no joy it's just frozen I've checked its recorded and purchased proper
Message posted on 17 Nov 2024 11:41 AM
Hi @Gazowens
