Discussion topic: Sky box office tnt recording won't play
This message was authored by: Gazowens
I've ordered the UFC event last night and it's recorded. But now it won't play when I selected from recordings
Re: Sky box office tnt recording won't play
Hi @Gazowens
Have you tried rebooting your Q box?
Avatar for Gazowens
Yeah mate no joy it's just frozen I've checked its recorded and purchased proper
Hi @Gazowens
