Discussion topic: Sky box not turning on
This message was authored by: CarolBanks
Just seems to be buffering  it says your screen will go blank,well we’ve been trying since 07.am this morning & it’s done it a few times since Friday last week!
This message was authored by: Stephen+Mourton
Re: Sky box not turning on
Have you tried resettling your box?  If not turn off the power at the plug or unplug the power lead from your box.  Leave it for at least 30 seconds and plug back in.  After a while it will tell you to press the 'House' key when it goes blank, but resist pressing it for a few minutes then press it and it will return you to the screen, and will hopefully work then.
