Discussion topic: Sky box not transmitting to tv via HDMI cable
Message posted on 20 May 2025 02:58 PM
Message posted on 20 May 2025 03:05 PM
Re: Sky box not transmitting to tv via HDMI cable
@PaulHamiltonjsy wrote:
I have an intermittent fault with my sky q box From standby, when it is switched on it fails to connect to the tv. Only happens 1 in 3 or 4 times but it's constant. Have to disconnect the hdmi and reconnect it. Then it works fine.
Have you tried a new HDMI cable?
Message posted on 20 May 2025 03:09 PM
Yes. I have 2 running to the tv. Have swapped them.
Message posted on 20 May 2025 04:39 PM
Does it fail to connect or does it just fail to switch the TV to the correct HDMI port?
Have you tried selecting the HDMI port manually when the issue occurs.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 20 May 2025 04:51 PM
@PaulHamiltonjsy is your Q box set to UHD by any chance ? if so try putting it back to 1080 setting and see if it helps
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 21 May 2025 12:25 PM
What TV? Is it an LG?
