Discussion topic: Sky box no signal
Message posted on 25 Jun 2023 08:57 PM
Sky box no signal
The Sky box has the green light on but the screen is blue with the tv saying "no signal"
Message posted on 25 Jun 2023 09:02 PM - last edited: 25 Jun 2023 09:03 PM
Re: Sky box no signal
Make sure that the TV set is set to the correct HDMI input for the Q box.
If it is and there is a green led on the Q box press
Home 1 0 8 0 Home
on the Q remote.
This will reset the Q box to standard 1080i resolution.
Message posted on 25 Jun 2023 09:04 PM
It does have a Green LED but that didn't work
Message posted on 25 Jun 2023 09:08 PM
My cable was loose! All sorted thanks for quick reply
Have you cycled through all the HDMI inputs on the TV set?
