Discussion topic: Sky box making strange noise, like loud fan
This message was authored by: JDLMNOP
How do I get sky Q box replaced?
Re: Sky box making strange noise, like loud fan
@JDLMNOP
Is the box situated in a well ventilated spot. Is it getting too hot (you should be able to rest the palm of your hand on it)?
▪️I AM NOT A SKY EMPLOYEE (not even undercover) ▪️
Have you restarted it by switching off at the plug for 30 seconds or so?
Avatar for JDLMNOP
Yes, done this a few times, have also removed all cables and checked connections too.
This message was authored by: GarethW55
Sky Q box making  making a noise. Sounds like a noisy fan or beating issue. Have tried power off etc but noise always returns
