Discussion topic: Sky box light is staying red and won’t turn on
Message posted on 23 Feb 2024 09:29 AM
We have tried to turn on our sky box and the light is staying red and won't turn on
Message posted on 23 Feb 2024 09:40 AM - last edited: 23 Feb 2024 09:41 AM
Re: Sky box light is staying red and won’t turn on
Hi @ShivviAran
Have you tried pressing the Standby button (Amber led) on the front of the sky box.
If this turns the Sky box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Sky box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Failing this,
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Ordering a new main Q box usually means a doorstep swap.
