Discussion topic: Sky box isn't working, it freezes when trying to change channels
Message posted on 29 Mar 2024 02:09 PM
My sky isnt working and freezes when I try to change channels
Message posted on 29 Mar 2024 03:20 PM
Re: Sky box isn't working, it freezes when trying to change channels
Hi @Sausage101
Try a Reset Settings in the main Q box hidden menu.
