Discussion topic: Sky box is on . We have no signal . Have restarted as instructed . Box lights up to red with blue ci
Message posted on 21 Jan 2024 10:55 AM
Sky box is lite up , now red . We have gone through on line instructions - the box briefly lit the blue circle and instructions appeared on screen but the box went back to red after not finishing process .
Message posted on 21 Jan 2024 11:00 AM
Re: Sky box is on . We have no signal . Have restarted as instructed . Box lights up to red with blu
Hi @Johnheslop
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
