20 Feb 2024 01:06 PM
Our sky box is frozen we have turned it off and on etc but still nothing.
20 Feb 2024 01:14 PM
Hi @Wayneargue
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
20 Feb 2024 01:17 PM
Hi @oldfella we just have the normal sky remote I did press the Q button on the (flashing blue) still nothing .
20 Feb 2024 01:27 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Wayneargue The Q button is not the on/off switch. It is over to the right.
20 Feb 2024 03:35 PM - last edited: 20 Feb 2024 03:36 PM
As per my post @Wayneargue
If this turns the Q box on.... reset your Bluetooth remote as per my earlier post.
Failing this
Hi
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Ordering a new Q box usually means a doorstep swap.
20 Feb 2024 03:39 PM
Posted by a Superuser, not a Sky employee. Find out moreIf the Q light is continually flashing blue with no picture appearing it could have failed. (That light is not a button)
also worth holding down the standby button for 10 seconds to attempt a forced reboot.
