Discussion topic: Sky box is connected to WiFi but says no network but it is working on other devices
This message was authored by: Chris419
I turned the sky box off at the mains accidentally and it took absolutely ages to come back on. When it did all recordings had gone. It won't connect to Internet now at all. Sky box is connected to WiFi but says no network but it is working on other devices. We've also tried connecting it via a cable, but still having no luck?
Re: Sky box is connected to WiFi but says no network but it is working on other devices
You have to do a full network reset if you change to ethernet.
The fact the recordings disappeared suggests maybe a serious problem.
@Chris419 Have you tried rebooting your main Q box again  ie
