Discussion topic: Sky box going on standby
This message was authored by: maggie.lee
The sky box keeps going on standby then turning back on. Done all the suggested fix problems but nothing works
Re: Sky box going on standby
@maggie.lee You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for maggie.lee
Level 2 icon
I have completed this thank you but all my apps have disappeared how do I get them back
@maggie.lee Have you tried rebooting your main Q box ie
if that doesnt work
you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
