12
This discussion topic has been answered Discussion topic: Sky box doesn’t connect to internet
This message was authored by: Millie5
I tried to reset connection but it did work - it heat searching what should I do
Re: Sky box doesn’t connect to internet
@Millie5 wrote:
Hi thanks for your reply.  It asks me to press and hold the WPS on broadband router which I assume is the one which corresponds to the remote? I don't find any WPS on Wi-Fi router.  So I tried to press the one on the sky box directly connected to TV but it's not working
Hi @Millie5
Using the one on the Q box will not connect it to the router.  You can only use WPS on the Sky Q broadband router
Location on Sky Broadband router is shown below
Hi @Millie5
Assume this. Is your main Q box.
Did you carry out a Network reset on the Q box.
Network Reset found in main Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Avatar for Millie5
Avatar for Millie5
i tried to connect through the second option which is to connect through Wi-Fi not supplied by Sky where I need to input password as my Wi-Fi router doesn't have a WPS button but it was unsuccessful as well
Hi @Millie5
Avatar for Millie5
Hi thank you very much it was a hard work to find that button! It's solved now.
This message was authored by: JulzB
I'm having the same issue - no internet connection according to Sky Q but all other devices are connected. I've followed the reset instructions and entered my password carefully several times, checking that it's correct. Repeatedly told that connection is unsuccessful & to check password. I don't know what else to do. My connection is via a dual band gaming router (I don't know what this is I had to look it up). I'd welcome some help.
This message was authored by: Gemmahutch
I've done all this but still not connecting, please help I'm going to cry. What do I try next
I eventually unplugged everything from the wall, went for a bath to relax & when I plugged it all back in again, although I got the same "not connected " message, when I put the password in it connected and has stayed that way. For now. 🤞
Which ISP?
Virgin Media but maybe the disconnect for longer will "reboot" the system. I'm afraid I'm not technical at all & thought I'd have to wait for my brother to come back from holiday. This was merely an act of desperation & hope. 😂
Glad yours is working now, but my question was to Gemma 🙂
Sorry. It came up in my inbox!
