Discussion topic: Sky box constant red light and i cant use voice control
This message was authored by HenrietteA This message was authored by: HenrietteA
When I try to use voice control it says im not connected to internet.
Been in setting and my broadband comes up, when I try to connect it keeps saying wrong password.
Changed password so sure its correct
I can use remote for going through chANNEL but can use voice control so cant get on Netflix etc
Re: Sky box constant red light and i cant use voice control
Hi @HenrietteA
HenrietteA
Have tried that twice and no luck, still red middle light on box and when trying to use voice control it says im not connectd to internet
Hi @HenrietteA
Assume you are not Recording or Downloading on your Q box.
This should only be the normal instance where the Q box middle led is Red.
Have you tried rebooting your Q box?
To completely reconnect your Q box to the internet :-
