Discussion topic: Sky box and mini not working properly and recordings gone
Message posted on 23 Apr 2024 05:49 PM
My main sky box has lost its recordings and my mini box is not working at all although home page is on but no tv guide picture
Message posted on 23 Apr 2024 05:54 PM
							Re: Sky box and mini not working properly and recordings gone
My sky boxes are not working technical fault came up on mini box also lost recordings
Message posted on 23 Apr 2024 06:12 PM
Hi @ffttss620
If you cannot make new recordings you possibly have a hard drive issue.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
