Discussion topic: Sky box always disconnects from internet
Message posted on 22 Apr 2025 08:06 PM
My Sky Q and minis keep disconnecting from the internet.
My internet is very good with 1GB download speed and nothing else has internet issues.
frustrating as I have to put in the password on the sky box and the minis.
Any Ideas please ??
Message posted on 22 Apr 2025 09:22 PM
Re: Sky box always disconnects from internet
Any Ideas please ??
@Arronx who is your broadband provider if its Sky which router do you have black or white ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 23 Apr 2025 01:24 PM
Seems to becoming a more frequently mentioned issue, been having this now for 6 months, regular disconnection from VM wifi, just SkyQ and minis no other appliances with issues.
Getting more and more flaky -
Today for instance "you have no internet" yet you go to settings and you get a "tick" for connection and if you go for "reset" you get told you are connected. Hmmm.
You'll be told to go for a wired connection, ignoring the fact that it should work WiFi.
Lookes at changing to Sky Stream but the more I read I still see lots of connection issues reported.
Message posted on 23 Apr 2025 01:37 PM
Always been a common problem
I can only repeat my previous suggestion of not using wifi if you want to keep all your own hair.
