Discussion topic: Sky booster not connecting to Sky Q
This message was authored by: Judi46958
Sky booster has stopped working and will not reconnect to Sky Q
Re: Sky booster not connecting to Sky Q
Hi @Judi46958
Is your Sky Q booster being used to connect your Q box to your Sky router or a Q mini?
Avatar for Judi46958
It is to boost the signal from the Sky Q box downstairs  to a Sky Q mini upstairs. It's been working fine for over a year and it lost connection for some reason and will now not reconnect.
Hi @Judi46958
If you main Q box is successfully connected to your Sky router then you can use the Q booster located between your main Q box and the mini.
Assuming the main Q box is connected correctly you need to set up the Q booster as follows.
Position the booster approx midway between the main Q box and the mini.
  1. Hold the WPS button on your booster for 3 seconds until it flashes amber. Then hold the WPS button on the front of your main Q box for 3 seconds until it flashes amber - You'll need to do it within 2 minutes.
  2. After a few minutes, the connected light on the booster should  turn green. You're all set up.
Tip: Need to move your booster after you've connected, don't worry it will automatically reconnect when its moved as long as its within range of your main Q box.
Then carry out a Network Reset on the mini.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with Q device,
You will be asked to press the WPS button on the Q booster box (not the mini as the Network reset will start the mini WPS automatically).
We have done this repeatedly and the booster will still not connect.. 😔
Can you try it with the two devices closer together?
