Discussion topic: Sky been playing up for weeks, now won't work at all
Message posted on 06 May 2025 07:40 PM
My sky has been playing up for weeks and now it's not working
I need an engineer to visit
Message posted on 06 May 2025 07:45 PM
Re: Sky been playing up for weeks, now won't work at all
@GARRY28 You won't get an engineer visit by posting here, no one on the community knows who you are or where you live.
Also it would be helpful to post what the exact issue is, any on screen messages?
Message posted on 06 May 2025 07:46 PM
Then you need to contact Sky directly @GARRY28
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue,
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
@GARRY28 wrote:My sky has been playing up for weeks and now it's not working
It may help if you explain what 'not working' is?
...we're other customers here so cannot arrange that. Give Sky a call (but see if we can advise first by expanding).
