Discussion topic: Sky a main box fault
Message posted on 06 Sep 2024 06:04 PM
Won't record or pause
Message posted on 06 Sep 2024 06:19 PM
Re: Sky a main box fault
Any messages about hard disk?
Message posted on 06 Sep 2024 06:28 PM
Hi @James277
First Have you tried rebooting your Q box?
If you still have the same issue
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
