Discussion topic: Sky a box not working properly only getting a couple of channels rest say no satellite signal
Message posted on 14 Jul 2024 09:59 AM
Only getting a couple of channels rest say no satalite signal
Message posted on 14 Jul 2024 10:52 AM
Re: Sky a box not working properly only getting a couple of channels rest say no satellite signal
@rikkiehenderson
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
