Discussion topic: Sky a box fine but mini box stating technical fault on all channels, performed reset on sky a box
This message was authored by: Cassie2
Internet connection is fine
Re: Sky a box fine but mini box stating technical fault on all channels, performed reset on sky a bo
Hi @Cassie2
Reboot the mini as above.
