Discussion topic: Sky a box fault
Message posted on 25 Aug 2025 10:52 AM
Sky a box fault
When changing channel the screen goes black and returns to original channel, while watching a recording if I try to fast forward the progress bar at the bottom of the screen keeps jumping backwards. On my sky mini box I am getting the message no satellite signal. When I look at the settings on my main box and look at network connection the network name has changed to a Sky network and my broadband provider is BT I have changed it back to BT but it changes itself back to Sky.
Message posted on 25 Aug 2025 11:31 AM
Re: Sky a box fault
Hi @Alanme If the broadband connection works, you can safely ignore what it says on the Sky network name. Mine says a BT router that I stopped using over two years ago and am now with Gigaclear.
