Discussion topic: Sky WiFi not working.. I have skyQ, tells me to reinsert card, but I don't have one
Message posted on 08 Apr 2024 09:02 PM
Message posted on 08 Apr 2024 09:34 PM
Re: Sky WiFi not working.. I have skyQ, tells me to reinsert card, but I don't have one
If you don't have a viewing card, then you can't do much with sky q,
Message posted on 09 Apr 2024 07:52 AM
@Jeannieb Your Q box will have a viewing card if you watch any Sky TV service check the right hand side the card slot is theree pres the edge of tge cardcand it should pop out clean the gold conracts with a soft dry cloth and press the card back in.
If you are using an old Q box tonwatch free channels then unfortunately you can't eatch the channel thst gives you that message as it is encrypted.
Message posted on 09 Apr 2024 10:13 AM
Thanks I have done that and it works....
I didn't know there was a card only had it 6 months
Thanks another learning day
