27
This discussion topic has been answered Discussion topic: Sky UHD is so dull it’s not worth watching
This message was authored by: Vino
How do I improve the brightness and contrast when watching Sky Sports on UHD...?????
This message was authored by: BenJoBanjo Answer
Re: Sky UHD is so dull it’s not worth watching
@Vino
By making sure your TV is set up correctly and has a high enough peak brightness for the HLG format of HDR that Sky uses.
@Vino
You can set your UHD output to 8bit so it doesn't do HLG if your TV doesn't go bright enough to handle it well. Normal HDR10 from apps like netflix and prime will also stop working though so you might want to use TV apps for those rather than keeping swapping the Q's output setting.
This message was authored by: cuke
What is the make/model of your tv as maybe we can suggest some settings to use..
Avatar for Vino
Hi Cuke,
TV......Samsung..55"...4K..
Is this any help...??
No.  Exact model needed.
Avatar for Vino
Thank you for your reply...
TV Model..
UE55NU7021....
Peak of just 350 nits.  Unfortunately, nowhere near enough to display HLG without being dull.  (Recommendation is at least double that)
Avatar for Vino
Thanks a million for that..
I'll check this out.
This message was authored by: MPos1971
Would you know what my LG is please, for the same reason?
LG55NANO816QA
LG55NANO816QA
Only around 325 nits.  The reviews criticised it's HDR performance: "The HDR peak brightness is mediocre. Small highlights get a lot brighter than in SDR, but it's still not enough for a true cinematic HDR experience, and the TV can't maintain high levels of peak brightness the longer a bright object stays on the screen."
Oh dear! Where do you find this kind of info please for future reference?
Hi @MPos1971   Try googling display specifications if the manufacturer doesn't publish the full specifications. Just as a comparison, my old Sony TV was 1500 nits with an excellent HLG HDR picture.
I can't see it written anywhere, where might PandJ2020 have found the Nits level?
You can just Google the TV make/model and the word "nits" and usually get a decent hit.
Firms like RTings in the US do a lot of panel testing so you will often find a number associated with any review, or on the manufacturers spec page for the TV.
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | sky Mobile | VOXI Mobile | SONOS Beam 2 | Apple TV 4K | EE Full Works FTTC
