Discussion topic: Sky TV not working
This message was authored by: Hits316
Sky TV not working
Sky q shows the tv channels but when i select a channel i just get a black screen, there is no messages on the screen neither, plus recordings don't work neither.
Re: Sky TV not working
Hi @Hits316 Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
Avatar for Hits316
I hav e turned the power off and then put it back on after 30 seconds but still no Sky TV.
Avatar for Hits316
By the way the sky box does not show any channels either.
Also try working through this: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
It could also be a hard disk issue: https://www.sky.com/help/articles/sky-q-hard-drive-errors
Otherwise, you'll need to call Sky for an engineer.
