Discussion topic: Sky TV not connecting to wifi
Message posted on 31 Aug 2024 10:09 AM
I have sky broadband and sky TV but I cannot get the TV to connect to the wifi. I've tried everything on the help pages. When we click reset it will reset and then when we click continue to confirm connecting to a new broadband it does not let us click this button (nothing happens).
Message posted on 31 Aug 2024 11:37 AM
Re: Sky TV not connecting to wifi
Hi @mollyannivy
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
If you still have issues with the remote during the setup press and hold 7 & 9 on the remote until it's led flashes four times.
This will set the remote to infrared mode which will work all Q boxes in line of site.
Reboot the Q box and then see if the remote will then let you complete the Network reset above.
Remember to point the remote directly at the Q box while it it in infrared mode
If you can get the Q working then re pair the remote by pressing 1 & 3 and following onscreen instructions.
Message posted on 31 Aug 2024 12:35 PM
Hi,
Ive done this and it still won't let us connect to wifi.
Message posted on 31 Aug 2024 04:31 PM
@mollyannivy wrote:
Hi,
Hi @mollyannivy .
Who is your Broadband provider and exactly what happens when you carry out the Network reset on your Q box?
Message posted on 02 Sep 2024 12:34 PM
Hi,
Were with Sky. We click reset and then it comes up with we cannot connect you to the internet right now. Would you like to continue?
We click confirm and nothing happens. There are no problems with the remote as we are able to click cancel.
Message posted on 05 Sep 2024 04:20 PM
Hi,
Im still looking for some help with this please.
