Discussion topic: Sky TV not connecting to network
Message posted on 07 May 2024 03:11 PM
I have Sky TV, Sky Internet and Sky Mobile.
My Sky TV is not connecting to the network i.e. the tv guide is not syncing or visable, even though the channels are accesable.
I have been through all the reccommended steps (how to recconnect) a number of times but am still having no luck. How can I arrange a technician to come to my house to fix?
Message posted on 07 May 2024 04:18 PM
Re: Sky TV not connecting to network
@Ollitoms This is a customer forum, to get an engineer you would need to call Sky. Is this your main box or a mini you are having issues with?
Message posted on 07 May 2024 04:26 PM
@Ollitoms You've posted in the Sky Q forum, as susch Sky Q received live channels & the TV guide over satellite and does not rely on the internet, do you havce Sky Q?
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Message posted on 07 May 2024 04:46 PM
Thanks...
Yes I do have Sky Q. Does that mean it's an issue with the satelite dish?
Regards,
Oliver
Message posted on 07 May 2024 04:47 PM
it's both
Message posted on 07 May 2024 04:49 PM
@Ollitoms Have you tried restarting the boxes by switching them off at the mains and lettin them boot back up.
Message posted on 09 May 2024 08:40 AM
yes i've tried that one. Just going through all the steps again now.
Message posted on 09 May 2024 06:00 PM
Hi @Ollitoms
Try the following .
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Wait until the router is completely back and running and then try a Network Reset found in main Q box Home - Settings - Setup - Network.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
When the main Q box is back up and running reboot the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
As soon as the mini is back up and running try another Network Reset on the mini.
If the Sky Router is nearer to the mini than the main Q box then you can use WPS on the router instead of the main Q box.
Message posted on 10 May 2024 04:54 PM
In my experience, you have to call Sky, to get to speak to an actual person say that you are leaving them because of your signal issues, they will then transfer you to technical because apparently they are the only dept that can booke engineers and if your lucky you might get an engineer in two weeks (mine was 12 days)...Good luck🤞 you'll need it
