Discussion topic: Sky TV isn't working! All the channels are showing but keeps showing technical fault
This message was authored by: Aaronoafc
Technical fault showing, cannot view any programs
Re: Sky TV isn't working! All the channels are showing but keeps showing technical fault
Hi @Aaronoafc
Have you tried rebooting the Q box.
Avatar for Aaronoafc
Hi, my partner has tried all this but still no luck 🙁 we will try again and see if there is any change
Thank you
This message was authored by: Southpole
We've been having the same issue since last Thursday. At first thought it was the bad weather on Thursday as there was some wind & rain (light) but it has continued since and weather is fine. Happening on most all channels & recordings. Every minute getting the blue screen and message 'This channel is currently affected by a problem with your satellite signal' or 'There is a technical fault with this channel'. Impossible to watch anything on live TV. Have restarted box a few times & checked all cables in back are ok. No difference. Thinking may have to book an engineer visit.
Only just noticed that there are quite a few new posts from today all saying they are having the same 'no satellite signal' issues as us.. so we're not alone. Something isn't right.. We've had our Sky Q box for 14yrs and only had this on the odd very stormy night before, but never like this for 7 days (so far..). Oddly, last weekend Sky Q box was also losing WiFi constantly. No other WiFi issues in home. Rebooted Sky router a couple times to see if it would help but didn't. After restarting Sky Q box a couple times it now seems to be fine but strangely when I do a Sky broadband service check it still says there's an issue with poor wifi. Other things connected to our WiFi all seem fine though and nothing has been changed or moved recently to cause this. Plus Sky Q box has been crashing/freezing nearly once a week recently which never happened so often before and sometimes issues with rewinding live TV and have to reboot Sky Q box to fix. May be time for a new box also? This is all so frustrating and we've spent hours this week trying to sort these recent issues. Hope someone here can help with the 'no signal' issue. Nearest appointment for engineer visit is July 14! 😩
@Southpole wrote:
We've had our Sky Q box for 14yrs  😩
@Southpole
Sky Q was introduced 7 years ago in 2016.
Perhaps try the troubleshooting on this link but I think you'll have to get an engineer to at least check your dish isn't out of alignment
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
@Daniel0210 Realised my error re: having Sky Q box for 14yrs and was about to correct when I saw your early reply.
Thanks for link. Will have a look and try the troubleshooting. Was also wondering if dish might be out of alignment but then so many others reporting the same issue recently.
@Daniel0210 Didn't realise but had tried the troubleshooting on that link already a few days ago. It's no help at all, everything checks out on it, but thanks anyway..
This message was authored by: Solant
I also have the same issue.  I have tried all therecomended fixes.
it is now stuck on Blue screen with
"There is a problem with your satellite signal.
 Your recordings an on demand service may still be available.
for help press ?"
