3
This discussion topic has been answered Discussion topic: Sky Remote not working and can’t connect via sky go
This message was authored by: gem87
Our Sky Q remote has stopped working and I've tried the steps to reset it and connect it up again but it's not coming up with the options after holding down 1&3.
I've tried to use the remote feature on the Sky Go app, but it's saying no Sky Q boxes can be found. Both the box and my phone are on the same WiFi network (we do have a mesh network but I've made sure my phone is connected to the same one as the box).
Any ideas on how I can get it working?
Thanks!
Re: Sky Remote not working and can’t connect via sky go
Thanks!
Hi @gem87
First try rebooting your Q box.
Once the Q box is on with green led try completly resetting your Bluetooth remote again.
Thanks!
Hi @gem87
This message was authored by: Stitch12
I have this exact problem and have requested a new remote from sky - in the meantime I cannot control my sky go box as the sky go app won't find my sky box????
Solved it - had to go into the sky go app settings and allow network access
