Discussion topic: Sky Qbox picture freezes
This message was authored by: Malvern+Michael
When watching sky the picture sometimes freezes and if i pause live program it won't restart, any ideas please
Re: Sky Qbox picture freezes
@Malvern+Michael Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Malvern+Michael
Yes thanks I have tried it twice but sadly no change
@Malvern+Michael You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
