Discussion topic: Sky Q
Message posted on 06 May 2026 08:18 PM
Sky Q
Our Sky Q box keeps losing connection to our broadband. Any suggestions?
Message posted on 07 May 2026 08:36 AM
Re: Sky Q
Someone suggested turning off the 2.4ghz in settings.
mine went off after I did that but hasn't since so I'm hoping it's sorted it.
Other than that I was told that routers firmware are more advanced now than Q so it will keep disconnecting.
Message posted on 07 May 2026 09:09 AM
Re: Sky Q
@Laurie1965 wrote:Our Sky Q box keeps losing connection to our broadband. Any suggestions?
If it loses it more overnight than during the day then try turning off the Q boxes eco setting entirely. If otherwise then is it possible to hardwire the box to the router? Or perhaps relocate the router so it has line of sight?
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
2 Windows desktop PC's hardwired to each Deco, everything else using the Deco WiFi
