Discussion topic: Sky Q.
This message was authored by: Emmsy+Sky
Sky Q.
I have sky Q. I have several multi room boxes around the house. I have moved one to a new room but its the room furthest away from the SkyQ box. TRhe error message says that there is no signal. Do you think I need a booster? If so do you supply them?
Re: Sky Q.
Hi @Emmsy+Sky
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home.
Regarding you mini connection issue.
First try rebooting the main Q box and then when this is completely back up and running reboot the problem mini.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If a previously connected mini is nearest then you can use WPS
Avatar for Emmsy+Sky
Re: Sky Q.
Thanks very much oldfella. I shall give all of that a go.
