Discussion topic: Sky Q
This message was authored by: Diane+Mccrindle
Sky Q
My sky Q mini boxes aren't working and cannot fix the problem on the main sky Q box can you help
Re: Sky Q
Hi @Diane+Mccrindle
Reboot the mini as above.
If the mini still does not connect try a Network Reset on the mini.  Start with the mini nearest to the main Q box
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.   If the first connected mini is nearer you can use the WPS on that.
