Discussion topic: Sky Q
Message posted on 03 Apr 2023 03:15 PM
Sky Q
Hi, I am due to have sky q installed shortly. My question is how will it work as my tv is on a wall & am looking for no wires etc to be visible. Can sky q go into another room?
Many thanks
Message posted on 03 Apr 2023 03:29 PM - last edited: 03 Apr 2023 03:31 PM
Re: Sky Q
Many thanks
Not unless it's in the room immediately behind the TV and can drill through the Wall for the HDMI cable which connects the Q box to the TV.
The Q Bluetooth remote should be able to work the Q box but the remote will need line of sight to the Q box to pair.
Also bear in mind that the Q box needs two cables from the satellite dish. These cables would have to come through an external wall and go to the Q box
Message posted on 04 Apr 2023 12:30 AM - last edited: 04 Apr 2023 12:31 AM
Re: Sky Q
Did you put the TV on the wall with no concealed HDMI cables going to it??
Message posted on 04 Apr 2023 06:42 AM
Re: Sky Q
Hi, I haven't put the tv on the wall yet.. I am due to get sky q shortly.
Many thanks
Message posted on 04 Apr 2023 07:23 AM
Re: Sky Q
@December+2022 wrote:Hi, I haven't put the tv on the wall yet.. I am due to get sky q shortly.
Many thanks
Ah. Channel HDMI & power cables into the plaster when you fit it.
Message posted on 04 Apr 2023 07:27 AM
Re: Sky Q
Do bear in mind that the HDMI cable from the SKY Q box to TV should ideally be less than 3m for 4K/UHD
Message posted on 04 Apr 2023 07:52 AM - last edited: 04 Apr 2023 07:54 AM
Re: Sky Q
Yeah you want to test them first ideally before plastering over & painting 😁 but people usually bury conduit wide enough to pull an hdmi plug through.
Message posted on 04 Apr 2023 07:59 AM
Re: Sky Q
Thanks all
Message posted on 04 Apr 2023 10:26 AM - last edited: 04 Apr 2023 10:28 AM
Re: Sky Q
Yes: a few Q users apparently choose to have a main Q box concealed (and without a screen) taking the satellite feed, and then use a Q Mini box behind a television receiving data wirelessly from the main box. This removes the option of having UHD content from Sky (because Mini boxes don't do UHD) and adds significant cost through the Multiscreen subscription, but apparently not having wires visible is more important.
For really advanced practitioners, there's the option of using HDbaseT AV distribution to client screens.
