Discussion topic: Sky Q won’t turn on and shows HDCP error.
This message was authored by: br6
Ever since I've upgraded to Sky Q, I've had issues with turning it on. Sometimes, it doesn't even turn on and the fans get loud on the box and the Q is illuminated blue and spinning. Then when it does turn on unpredictabley, it shows an error message.
"This screen does not support HDCP.
Try reconnecting your HDMI cable, or use a different screen". I've tried everything, multiple different HDMIs. And I can't keep turning it off and on, any help would be great, thanks.
This message was authored by: Addie15
Re: Sky Q won’t turn on and shows HDCP error.
Is this an LG? Is the software on it updated?
Avatar for br6
Yes. Software all updated.
This message was authored by: Playa1Gamer
Hi any luck I'm having same problem when you trun on sky q box error comes up then goes away after few seconds I have lg G4 oled
Hi there, @Playa1Gamer. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Avatar for br6
Yeah, I have the same Tv. Still getting the same issues. How about you?
Hi I will let you know once I have received my new hdmi cable
Avatar for br6
Thanks.
@br6  Haven't seen the HDCP error for a week now but only works in 8bit even though lg g4 is a 10bit panel oled
This message was authored by: Bob73
Ive started getting this on my LG C3  and sky Q only in the past few days, latest software on the TV 23.20.61
Tried different hdmi cables, stil the same.
