Discussion topic: Sky Q won’t recognise sky Wi-Fi
Message posted on 08 Dec 2023 01:05 PM
My sky q box won’t recognise my sky Wi-Fi, it’s been working fine and now it won’t pop up at all to even give me a choice to connect to it.
Message posted on 08 Dec 2023 03:37 PM
Re: Sky Q won’t recognise sky Wi-Fi
Hi @Tomk90
Try a Network Reset found in Q box Home - Settings - Setup - Network.
As you are on Sky broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Message posted on 08 Dec 2023 04:59 PM
Reboot your Sky router by pressing the button on the back of the router and then get your Q box to search for your WiFi network which should now show and you can then connect to it.
