Discussion topic: Sky Q with Ethernet cable but two mini boxes on wifi - can this work?
Message posted on 11 May 2025 02:47 PM
Hi, I thought I'd put an Ethernet cable from my Sky full fibre router to my Q box, but I'd have my two mini boxes via wifi. Is this possible and what settings would I need to adjust on the Q and mini boxes? Reason is that occasionally the router loses the Q box and I have to reset by saying it's on a third party broadband just so it finds the option and then I have to manually put in password. Pressing the WPS button never works.
Thank you.
Message posted on 11 May 2025 03:08 PM
Re: Sky Q with Ethernet cable but two mini boxes on wifi - can this work?
Thank you.
@Franski555 the first thing we need to know is do you have the black or the white router from Sky
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 11 May 2025 03:17 PM
Thank you! It's the white router.
Message posted on 11 May 2025 06:14 PM
That's the new Sky Max router @Franski555
Afraid that with Q this performs like a 3rd Party router and if using WiFi connection on your main Q box you do need to use the SSID and password for the 2.4 Ghz band.
However if using Ethernet then you need to carry out a Network reset on the main Q box with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router. Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
With the minis on WiFi they will not connect to the Max router and they need to connect to the main Q box WiFi.
Reboot the minis as above.
When you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or previously connected mini).
Message posted on 11 May 2025 06:17 PM
That's a great, comprehensive answer, thank you! I'll give it a go. 😀
Message posted on 12 May 2025 05:30 AM
Also I recommend you disable 2.4GHz wifi on the main box.
Message posted on 12 May 2025 06:47 AM
Thank you!
