Discussion topic: Sky Q wifi connection speed
Message posted on 26 Oct 2024 01:00 PM
Hi. My Sky Q box is connected via wifi to my new Nokia router less than 6 feet away. Router is high speed fibre sending out over 200mbps to other home devices (i've done speed tests) yet i can barely get my Sky Q box above 20mbps when i check speed via Netflix app. I've reset both router and Sky Q, also updated to latest firmware, no joy. Why is this happening??!! It's actually causing issues downloading programs and streaming is glitchy.
Message posted on 26 Oct 2024 02:53 PM
Re: Sky Q wifi connection speed
Hi @Bruce+Lee
You will not get anything like 200 mbps on the Q box but 20 mbps is certainly very low.
Try a Reset Settings in the Q box hidden menu. See if that helps.
Failing this have you considered connecting your Q box by Ethernet to your router
Message posted on 26 Oct 2024 05:55 PM
Thanks v much for this advice oldfella, didn't know about hidden settings. So i got cheesed and took an ethernet through wall this avo from diner to lounge, hardwired as you suggested and now at 50mbps. Much better, though still surprised it's not nearer 100 but that's just probably my lack of tech knowledge.
thanks again, v useful
Message posted on 27 Oct 2024 08:09 AM
Netflix tops out at about 24Mb anyway for 4K HDR content. You shouldn't get glitches at that kind of connection speed but I can believe it wouldn't give you the best picture quality.
If it's only 6 feet away can you just use ethernet?
Might be some contention on the 2.4GHz spectrum if other devices are using it.
