Discussion topic: Sky Q volume up and down.
Message posted on 08 Mar 2023 07:57 PM
Suddenly, after years of service, my sky Q volume has started going up and down for no reason. It seems to be on recordings and catchup only.
I have turned the box off at the mains with no difference. It is on the main Sky Q box only and not the small box in the bedroom.
I am not sure in this case if it is the main TV, a new samsung.
Message posted on 08 Mar 2023 08:02 PM
Re: Sky Q volume up and down.
Hi @dghand Check the HDMI audio format output in the Q box.
As it is a new Samsung it should take Dolby Digital
Home - Settings - Setup - Audio Visual.
HDMI audio format.
The first thing I'd be doing is, just to be sure, swap the batteries on the remote/s and also, reset the remote:
Press 7 & 9 together on the remote until it’s led flashes four times.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes twice and follow onscreen instructions to re- pair. (Credit to @oldfella here).
Then, I'd be swapping the TV's over for an evening to see if the issue "follows" the TV or stays with the main box.
Good luck
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
