22 Oct 2024 04:34 PM
Sky Q voice control model remote volume control suddenly doesn't work but every other function is fine. I tried all the reset options and pairing but no luck so I purchased a new remote which paired with my TV and that's exactly the same!!
22 Oct 2024 05:05 PM
@gettingwiser Have you tried rebooting your main Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
if that doesn't work try
rebooting your TV
ten re-pairing the remote
