Discussion topic: Sky Q voice control remote problem. Everything works except the volume and mute which have suddenlyl
Message posted on 22 Oct 2024 04:34 PM
Sky Q voice control model remote volume control suddenly doesn't work but every other function is fine. I tried all the reset options and pairing but no luck so I purchased a new remote which paired with my TV and that's exactly the same!!
Message posted on 22 Oct 2024 05:05 PM
Re: Sky Q voice control remote problem. Everything works except the volume and mute which have sudde
@gettingwiser Have you tried rebooting your main Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
if that doesn't work try
rebooting your TV
ten re-pairing the remote
Message posted on 22 Oct 2024 09:23 PM
Thanks but I've done all that, in fact having paired the new remote I had to turn off my Sony TV and reboot it just so I could use the volume control on the TV remote whilst using the Sky remote for everything else!!
I don't seem to have missed a Sony software update either.
Message posted on 28 Oct 2024 12:37 PM
OK problem solved.
On another forum "oldfella" said to access the remote reset option from the Q settings on the TV and follow the same instructions from there.
It worked first time after entering Sony TV model info.
So instead of just starting with 1 & 3 method which didn't work on either remote the Q settings option did but only with the new one so my old one had run it's course.
