Discussion topic: Sky Q ultra HD
Message posted on 08 Aug 2024 02:31 PM
Sky Q ultra HD
Upgraded to Sky Q cannot receive Ultra HD sky engineer said the HDMI lead was faulty not so, changed the same!
Message posted on 08 Aug 2024 02:36 PM - last edited: 08 Aug 2024 02:37 PM
Re: Sky Q ultra HD
hi @REC1
Check which box you have :
If it is 32Cxxx then you have an older 1TB non-UHD Box
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply)
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box
https://www.sky.com/help/articles/check-which-sky-q-box
If you have a non UHD box & wish to upgrade you will need to call SKY - there will usually be a fee of around £100 although it can be lower
To watch SKY content in 4K you also need the UHD add on
If you do have a UHD box then be let us know what make & model of TV for us to give more advice
Message posted on 08 Aug 2024 02:38 PM
Re: Sky Q ultra HD
Hi @REC1
Have you set your Q box to 2160p resolution.
Also your Television set needs the Q HDMI input set to receive UHD.
See following help link
https://www.sky.com/help/articles/setting-up-ultra-hd
Message posted on 08 Aug 2024 02:42 PM
Re: Sky Q ultra HD
I have not changed anything on the box assuming the engineer would have done all that. he said the lead was fauly
Message posted on 08 Aug 2024 02:47 PM
Re: Sky Q ultra HD
@REC1 wrote:I have not changed anything on the box assuming the engineer would have done all that. he said the lead was fauly
Never assume... But do check the hardware version table above and bear in mind you also need a HD and UHD subscription to get any native material in UHD... (The output needs to be 2160P of course)
Message posted on 08 Aug 2024 04:24 PM
Re: Sky Q ultra HD
I assume the installer tried to set the box to 2160p and it didn't work hence their suspicion of the cable. If so that would suggest the box is UHD capable.
Changed the HDMI lead to what?
Message posted on 13 Aug 2024 02:05 PM
Re: Sky Q ultra HD
To another HDMI lead so eliminated the lead as faulty.
Message posted on 13 Aug 2024 02:14 PM - last edited: 13 Aug 2024 02:14 PM
Re: Sky Q ultra HD
@REC1 wrote:To another HDMI lead so eliminated the lead as faulty.
And your hw version is? And can you select 2160P in display settings? Can the TV receive 4K in the used port?
Message posted on 13 Aug 2024 02:28 PM
Re: Sky Q ultra HD
Not all HDMI cables are the same. You need to use at least a high speed HDMI 2.0 cable which has sufficient bandwidth to transfer UHD and HDR content between the Q box and your TV.
Message posted on 15 Aug 2024 09:54 AM
Re: Sky Q ultra HD
Check all that as been asked and have a 4k Sony the HDMI lead is a 4k high speed cable.
On some programmes it comes on top left "to watch in UHD press red button" doing that only brings up a message saying there is a technical problem please try later!
Why does sky not have its own tech help or a engineers service rather than a community of helpers. Surely paying over a £1000 a year and have done for over 20 years would expect service direct from them? Also supposingly being a VIP customer or is that just a marketing ploy.....
Message posted on 15 Aug 2024 11:01 AM
Re: Sky Q ultra HD
@REC1 wrote:Why does sky not have its own tech help or a engineers service rather than a community of helpers. Surely paying over a £1000 a year and have done for over 20 years would expect service direct from them?
They do, but you'll have to call to arrange a visit.
There's only so much we can do...
Message posted on 15 Aug 2024 11:05 AM
Re: Sky Q ultra HD
cheers all
