Discussion topic: Sky Q to mini via ethernet stopped working.
Avatar for lorri66
Level 2 icon
This message was authored by: lorri66
Re: Sky Q to mini via ethernet stopped working.
Yes i have just done reconnect to hub but status says not connected.
connected to broadband router but no internet.
all was ok until i actually turned off the hub last night. Mistake.
Hi @lorri66
You don't connect the mini to anything.
Just carry out the Network reset on the mini with the Ethernet connected as per my post.
Ethernet is still connected between mini and Main Q box I assume?
Avatar for lorri66
Level 2 icon
Yes it is & will follow what you have said tomorrow. Thank you for help
Avatar for lorri66
Level 2 icon
Didn't need to do anything in the end as when I went to try and sort all armed with instructions turned it on and low and behold it was working!!!
thank you for all your help though.
Glad it is now working OK for you
